- Joined
- 27 Jan 2008
- Messages
- 28,738
- Reaction score
- 3,508
- Location
- Country
I understand your thoughts, but consider does it matter? One of the things my calculation pointed out to me was the loop impedance or short circuit current measurement will vary each time one measures, so in real terms the calculated result is an approximation and really only an indicator.
Yes it gives a warning that one is close to the limit or over the limit, but it's not good enough to tell anyone they are non compliant.
One would need to measure when nothing has been used for hours to ensure all the cable was cold. In real terms few cables have the same installation method throughout their run and flit between methods and one sees how the results change.
So where there is a fault likely caused by volt drop then the calculation will likely confirm or reject ones suspicions but at best it's only an indication.
