N
NeoX
I am in the process of having a bathroom installed by a builder and have been having some serious problems with the tiling which have been discussed here. However, this threw up some further potential issues concerning the electrics as the builder is not certified to issue BS 7671 Design, Installation and Test Certificates.
I also did not seek Building Regulations approval before work commenced so I have this evening kicked off a Regularisation application with Newham Council. I understand this will mean an inspector will come and check the electrics at my expense, but I was told on the other topic that he may only be able to issue a 'completion certificate' under Part P, but not a 'wiring certificate'.
Is this true, and, if so, what are the implications? What options do I have?
Also, generally, I'm starting to wonder if I should just draft in a certified electrician to do the remaining electrics and certify the existing electrics (redoing as necessary) because the steam shower must be on its own circuit, and I believe all the bathroom electrics must be on RCD switches. My installer seemed a little nonchalant about this.
I've posted a job on MyBuilder to this effect just in case!
Any advice would be greatly appreciated at this late stage
