Is there a laminate filler?
OM2
18 Jan 2007
I have a few problems with laminate flooring
Firstly, I need to fill gaps. In a few places, two pieces have developed a gap in between. If I could get a filler to conceal the gap, that would be great
Secondly, in some parts, there has been water damage and the laminate can be visibly seen to be raised in parts
What can i do? Would be a crazy idea to try and sand down? I'm thinking that would be silly because the wood is very thin!
Thirdly, is it feasible to replace a few strips of laminate? The laminate is at least 10 years old!! :)
Just looking for advice
OM
You can replace laminate strips but they will stand out.
Water damage laminate has to be replaced - maybe the underlay is also damaged?
Why have the gaps developed? Is it connected with the water damage?
Perhaps, post pics of the floor on here?
You really have to make a call: do i spend and repair or do i spend more and replace?
@ree thanks for the reply
some of the laminates is raised because of water damage
other parts - i have no explanation
as for pictures... it's really hard to show the raised surface in pictures
see below for a pic, u can see a gap on the bottom right hand side:
The laminate might not have originally had an expansion gap at the ends and edges, and against all abutments including thresholds and pipes.
A 10-12mm gap all around is safe.
Perhaps remove the scotia behind the rad and see if you have expansion room. The rad pipes seem tight - are they? You could chisel an expansion gap around the pipes and cover with a split escutcheon ring.
To be brief: if you replace the raised, water damaged lengths then do the same either side of the "gap".
All finished floors rely on preparation, of course. They will then hold out best against most kinds of movement.
  • Thanks
Reactions: OM2
as an aside
cheap laminate is no more than a plastic wear layer a printed paper patern and a backing off mdf/chipboard or if its water resistant plastic moulding
  • Thanks
Reactions: OM2
as an aside
This.
Buy replacement boards that match or replace the lot.
If it is floating (likely), and if you can find boards to match and replace the rest, you can likely take the floor apart somewhat, relay the boards tight to get rid of the gaps, filling gaps is going to look rubbish.
