Hi all,
We are in the middle of having all sorts of landscaping and groundworks completed around our house. Currently, we have the rear patio dug up ready for a new one to go down. I've also demolished the old shed and lifted the slab base it was on.
Before our tradesmen start putting the new patio down, I want to make preparations for an SWA cable to go in from our main CU to a secondary CU that will go in the new shed - a 25m reel of SWA will give about 2m spare each end, as the accurate distance is closer to 21m once all of the bends are accounted for.
I'm trying to understand for my own peace of mind what size SWA cable should be appropriate and what its route should be so I can dig the right trench in the right place. I'm thinking the best approach will be to simply install conduit and worry about the cable later but Friday afternoon curiosity has got the better of me...
The plan is to run the SWA straight out the wall from the CU and along the side of the house (clipped to the brickwork) for 11m then down under the new patio, the existing garden and coming up at the site of the new shed another 10m away - so 11m clipped in air & 10m buried underground. I plan initially to have just a simple light circuit in the shed and provision for a couple of sockets in the shed, plus a couple outside for garden tools, however I want to put some future-proofing in to save me digging stuff up or buying new cable! For the same reason I'm going for 4-core SWA (just in case!)
Using TLC's voltage drop calculator I get this:
View media item 80497
From everything I've studied, 2.5mm just seems small. I can't help think I'm missing something and 4mm will be better? I've allowed for 5kW in the above calculation which should give me a fair bit of headroom.
What do people think?
Any advice on conduit to use would be good too - I need about 12m in one run if possible.
