Max load for 2 brackets (curtain pole)
26 Oct 2012
Derbyshire
Hi all,
Roughly what weight and span would I need a third central bracket? My pole is 185cm and the weight is 4.5kg, would 2 brackets cope?
Hi all,
Possibly, but how sturdy is your pole?
Cheers
Richard
Pole is plenty study enough - I think two brackets with decent fixings should do it, just thought there may be a sought of weight threshold where 3 are needed. I guess anything >200cm would always need 3?
Hi all,
Cheers
Richard
Probably. Try it with two and see.
Cheers
Richard
You need three when the curtain causes the centre of the pole to sag , if it does not sag then you have enough support.
