I wrote nothing which was rude.Why do you have to be so rude?
What you did was to screw up quoting again, and again not bother to put it right.All I did was state fact. Said nothing about doing a good job or not.
It wasn't rhetoricalYes, we agree. I stated my understanding of the situation and you asked a rhetoric question (in the 'original' thread)I thought that, strictly speaking, all 'electrical work' undertaken per BS7671 required testing and an MWC (or EIC), and confess that I hadn't noticed the exception to which you refer relating to 'like-for-like 'maintenance' replacement".Does BS 7671 allow you to sign an EIC to say that you'd complied with the regulations when replacing a damaged switch when it would not have allowed you to do so if you had replaced it for aesthetic reasons?
Apologies - at the time I was not aware of that.As you will be aware, I started a new thread about this issue yesterday.
Hmmm. It would only really 'not be rhetorical' if you didn't know the answer - and, unless I'm over-estimating you, I think that you do know the answer!It wasn't rhetorical
If your not careful, BAS will be telling you off for your 'bad job' at formatting that messageHas the definition of 'rhetorical' changed then John? Must update my dictionary.It would only really 'not be rhetorical' if you didn't know the answer![]()
I agree that it does not explicitly say that one only uses a rhetortical question when one doesn't need 'to elicit information' (since one already knows the answer) - but that is surely the implication, and definitely the 'common usage'.Oxford Dictionaries said:Rhetorical. ADJECTIVE. .... 2. (Of a question) asked in order to produce an effect or to make a statement rather than to elicit information.
If your not careful, BAS will be telling you off for your 'bad job' at formatting that message![]()
It really must be 'a quiet day at work' !!If your not careful, BAS will be telling you off for your 'bad job' at formatting that message![]()
Splitting hairs? Moi? Pot, kettle...Anyway, are you just splitting hairs or what? If you want to update your dictionary, you might want to look at:It must be 'a quiet day at work' because, all the above aside, both you and BAS knew exactly what I meantOxford Dictionaries said:Rhetorical. ADJECTIVE. .... 2. (Of a question) asked in order to produce an effect or to make a statement rather than to elicit information.![]()
I admitted that it it did not explicitly say that. However, it does say that a rhetorical question is not asked 'to illicit information', and it also says that the question is asked 'to produce an effect or make a statement' - so, common sense suggests that a rhetorical question would not be asked unless the questioner was pretty sure that (s)he knew the answer, since otherwise they might not be 'producing the effect or making the statement' that they intended!Yes, that is the OED definition. What does it say about knowing the answer (or not)?![]()
