having 22" walls and solid floors make it no small task. :
Decent SDS drill and drill bits will get there (eventually)
Sounds a bit worse than some of mine:But I want to put it much higher and for the lower bands, possibly multiple wires. Problem is that I have 55' from chimney down to the back of the property.
Happy shopping! Most of my activity, albeit mainly in the dim and distant past, was on VHF/UHF - so a whole different set of antenna issues!Am off to a rally in Sale in the morning to get some bits, a center & some insulators - a balun if I see one cheap enough etc.
Quite possibly not as long as in my case - my 'peak' was probably mid-60s to mid-70sLong time since I was active.
Thanks. I'm actually not quite as old as it might soundMmm.. you might have a slight edge on me. ... Congratulations on the RSGB membership. I let mine lapse, or I might have been on the list.
Similar kids issue here, but I never really had a renaissance in any serious way. By the time that might have happened, the world had 'moved on' so far that many of the attractions and appeals which has existed in the 60s and early 70s had largely evaporated!I'm being a born again ham, ticketed in the 90's then kids came along.
It still does (or 2.5 mm² if mechanically protected), but that's just for protective conductors in general. However, here we are talking about a Main Protective Bonding Conductor, and 544.1.1 specifies the minimum for that of 6 mm² (or 10 mm² minimum if PME)543.1.1 says 4 mm² min for protective conductor don't know if this has now changed.
Indeed. It was the potential dryness which led to the uncertainty I was expressing about 'under house' earth rods. Probably OK for a TT earth, but hard to get a decent low impedance for an RF one- so hence my comments about the alternatives to RF earths.I have put in earth rods under a floor. but reading was 60Ω as so dry.
Unless I'm going mad, that is surely all "upside down and back to front". The whole point (and danger) about extraneous-c-ps is that, if not Main Bonded, they can result in the inside of the building not being an equipotential zone, hence possibly containing dangerous potential differences between various conductive parts. It is surely the case that any conductor which appears out of the ground and enters a property must be regarded as an extraneous-conductive-part, and therefore needs Main Bonding.I stand to be corrected but my understanding is an earth rod in a house with a TN-C-S supply is not called a protective earth electrode it's called an extraneous-conductive-part if you can touch it from outside the house and an exposed-conductive-part if you can only touch it inside the house.
It doesn't matter what the earthing system is, or what one calls the rod - if it (or an extension of it) enters the building, then it surely represents an extraneous-c-p, which could introduce potential hazards into the premises. In practice, that's not usually an issue/problem, since if it's being used as an earth rod (connected to the installation's earth), the CSA of the 'earthing conductor' will usually be required to be at least as great (usually greater) than that required for Main Bonding. As per this discussion, an exception might exist if it were not being used as a supplement to the installation's earth but, rather, only as an 'RF earth' for equipment which essentially isolated it from the installation's earth (at least as far as 50Hz was concerned). If one did that, without Main Bonding, it clearly would represent a potential danger, since the building would no longer necessarily be an equipotential zone.Hence why some say you can't fit an earth electrode with a house with a TN-C-S supply you can physically fit the rod but it's not called an earth electrode.
As above, it would be difficult or impossible to have an earth which was not connected to the installation's earth directly connected to equipment within the building (as an 'RF earth') without creating a possible shock hazard. However, I imagine that the 'RF earth' could be effectively 'isolated' as far as 50Hz was concerned by inductive coupling (or even perhaps just a small capacitor) outside of the building. That would obviously be difficult for the OP, given that his earth rods will be entering the property through the cellar floor - but I suppose they could enter into insulated enclosures with the "50Hz isolation" within them.Since I have done very little with HF I can't really say what earth is required for the radio but really you would not want the radio connected to DNO earth directly as it could cause signal to be radiated from DNO cable into other properties.
