Magnaclean or what else would do
20 Jan 2012
Norwich
I want to install Magnaclean or an alternative device in the central heating system.
Question: What are your thoughts and advice of products suitable for this job and what do you think is the best product/make to use.
Magnaclean pro 2 is what i use. Easy to install because it comes with a slip coupling. They catch a lot more than some others on the market too
I'm going to have a look at the Spirotrap MB3 on my next few installs. Heard about some Magnacleans leaking on this forum and outside of the forum.
James.
I use the mb3
Not known of a leak on the magnaclean 2 but I'm not one to let lightning strike twice, hence why I don't fit vaillant or ideal boilers....
I think the magnaclean has the most powerful magnet but is made of plastic
What is your reason for fitting one? They are not a solution to a problem they are a preventative measure
I use the mb3
I,ve 25 radiators in total and a twin gas valve condensing boiler, I'm currently replacing and upgrading radiators to modern specs; so thought that fitting say a magnaclean would be worthwhile.
Currently hardly any debris;much has come out of the system and all radiators become hot all over; so really it is just an upgrade of the system with new rads where needed.
