I am redecorating my lounge which will entail the ceiling being newly boarded (on top of existing, not replacement), and a new plaster skim on the walls.
I have a socket in the lounge, cable coming down the wall. I want to move it about 16" to the right. The room above is a bedroom, but there are wardrobes in that area so I cannot get to the cable from above. I have two questions about this.
Firstly, the cable will not extend that far. I will need to join it. I am presuming I can just use a regular junction box that will be above the new ceiling plasterboard?
Secondly, the joists run in the wrong direction for me, there are two between the existing cable and where I want it to be. There is already one layer of plaster board, and this will be added to a second layer. Can I just channel out the existing plasterboard to the new channel and run the cable along there knowing the new layer of plasterboard will cover it? Do I need to encase it in conduit? Do I need to notch the two joists or even drill holes in them to channel the cable?
TIA.
TIA.
