electric hob and double oven
Do you think it's good practice to use a dedicated circuit to supply general various other appliances
It's not really 'various other appliances' - the cooker hood is part of the 'cooking set up'. Do you similarly feel that it is bad practice to run a gas hob's igniter from a cooker circuit?
... and how do you feel about cooker control units (fed from a cooker circuit) which include a 13A socket (presumably to be used for 'various other appliances')?
It's not really the same thing is it, those examples are rediculous
So you confirm you think that it would be good practice to spur off the cooker circuit in 2.5 to supply an extractor hood rather than to supply it from a ring final circuit
No they are not. Will you please answer the question about CCUs with sockets.
Will you please explain why you think it is bad practice to design a circuit to supply an oven, a hob, and an extractor hood.
Eh? What's "ridiculous" about a gas hob igniter or a socket in a CCU being fed from a cooker circuit - both of which are extremely common situations?
I don't really understand what you mean by 'good practice' and 'bad practice'. What I do think is that any circuit is acceptable if it is properly designed and constructed for the purpose(s) in question.
I really think it's down to you to explain what is 'bad practice' about what you describe ... and why it is worse that the ("ridiculous") concept of running a kettle, toaster, mixer or whatever off a socket in a CCU fed by the cooker circuit, or powering a gas hob from a spur from that circuit.
Pulling it off the cooker circuit is poor practice imho
I think it is a good idea and best practice.
I always do it if possible.
I am not a kitchen fitter in the derisory sense you meant but I have fitted kitchens
What do you understand by dedicated?
It would then be dedicated for all the cooking appliances.
Yes. 1.5mm² would do (subject to fault current).
Well how ever you try and justify it, its just not done like that professionally
Im not saying its against regs cause its not but given the choice why would you opt for that?
Would you supply a towel rail from a shower circuit just cause its in a bathroom?
Anyhoo I'm not here to preach or try and convert anybody, you crack on, ill crack on...
So why has a professional just said that he believes it to be "best practice"?
You have not really answered any of the questions posed to you about comparable situations, nor have you given us even one specific reason why it is 'not good practice'.
However, there is equally nothing wrong with how you would like to do it - so, as you say, you can just crack on.
You keep on making that basic assertion, and yet you have so far been unable or unwilling to explain what is unprofessional about designing a circuit to supply an oven, a hob and an extractor.
If the hood had no lights in it why would it be the done thing, professionally to connect it to a lighting circuit but not to the same ciruit as the appliances with which it is closely associated?
This cooker has an integrated extractor hood:
If you were asked to install one would you first get your tools out and rewire it so that the hood was separately powered, on the grounds that it is unprofessional to have the cooker and the hood on the same circuit?
How many times do you have to be asked "why would you not" before you give a proper answer?
Will you please explain what would be wrong with designing a circuit to supply a shower and a towel rail?
Before you crack on will you please answer the question about CCUs with sockets.
