potterton suprima 60 he
25 Sep 2014
Manchester
hi guys my potterton suprima 60 he isn't firing but pump is working and I have a green flashing led only on display help needed please cheers
Is your pump wired to be supplied from the boiler?
Have you checked for a call for heat at the boiler?
Tony
Tony
cheers for your response my pump is near the cylinder and when i turn the programmer on the wall on the pump kicks in but absolute nothing on the boiler if i disconect the the connectors at the pcb everyone turns a red led on except for the one which is at the back which looks like its wired to the ignition probes hope this makes sense cheers
This model of boiler is renowned for PCB failures. The PCB replacement kits are expensive, so my advice is to get a GSR engineer in to test and fix it.
Tony
Well it should be.
You dont tell where the pump is connected to by looking at lights. You need to look at the pump wires.
Or quicker see if anything is connected to the pump terminals at the boiler.
Tony
The pump should be connected to the boiler.
But you need to establish if there is a call for heat signal at the boiler.
Tony
it is not and never as been the boiler is controlled by a unit in the kitchen and the flashing led says its calling but nothing is happening
That seems a rather extreme response when you dont even know if there is a call for heat voltage on the appropriate terminal of the boiler!
Potty do a fixed price repair for about £300. An independent will be cheaper if its not anything serious. About the same if it needs a new PCB.
Most would say a storage tank is better than a combi hot water supply.
Tony
Flashing green light means the boiler thinks is up to temp, it could be something as simple as a slow running pump
