I have added an extension to my home and now have 3-way switching in the hall. I have followed the manufacturer's wiring instructions and they are the same as those wiring diagrams shown here on the forum and on other sites.
I will have an electrician come replace the existing consumer unit and approve the installation prior to signing off for building warrant, but it shouldn't be that complicated as the following is true-
The 3-way lighting is measuring 238-240V when any of the hall lighting is switched on, but when it's switched off there is still a residual voltage of 42-50V and this causes the LED downlighters to remain dimly illuminated.
All the switches allow the hall lighting to be turned on or off, but there is a residual voltage. There are 3-downlighters and I have fitted one while the other two cables are left disconnected. I fitted one down light just to check it was working ok before covering up with plasterboard.
The new extension has new harmonised cabling installed on all circuits including the lighting.
The lighting wiring checks out as the other 5 rooms have multiple lighting points and some with 2-way lighting and there are no similar issues.
I've read a few of the forums but haven't found the answer yet.
Does anyone know what the solution would be?
