Hi all, I’ve built myself a garden room and am currently after some advice regarding electrical work that needs to be carried out. I‘ve run the cables, and a sparky will be connecting everything. I’ve run a 35m length of 10MM SWA 3 Core from the house CU to the garden room. My House Consumer unit is a Dual RCD Wylex with a spare MCB space. The garden room will have its own (small) CU.
So I have a few questions::
1) How many amps will this allow me to have at the garden room Consumer Unit after voltage drop is accounted for?
2) Would it be suitable / possible to able to use a RCBO in my House Consumer unit (in spare MCB socket) so that if something outside trips it won’t take out half the house? Or would it be better to have a couple of RCBO’s in the consumer unit in garden room, Or some sort of secondary fused isolator (for a totally different supply) near the main CU indoors? What would be the best practice here?
3) There will be no Water/Gas Pipes in the Garden room, will an earth spike be required? Or would I use the earth from the House CU?
I will be getting a qualified sparky in to do this, but want to order all the parts in advance. I know I’ve asked a lot of questions, so I’d like to thank you in advance for your help!
