- Joined
- 31 Aug 2005
- Messages
- 4,724
- Reaction score
- 939
- Country
If anyone can help with issues below with image quality etc would be grateful.
DVR Equipment
DVR Unit: Samsung: DVR SRD443
Cameras: Samsung SCV-2081R
Im using IE11 and struggling to get the Web admin/remote viewing interface to load, there's issues with the webcamviewer.cab activeX components loading? I tried setting most Browser settings from disable to prompt but still not loading the live feed components or setup/configure components. Just a shell, nothing working.
Abandoned all attempts in the end and tried firefox, this was some improvement but i needed Silverlight instead. That loaded the web admin interface but will albeit limited functionality. And the cam views were crap, especially at night its like the camera was swarmed with bees, seems there is constant what looks like jpeg dithering effect going on. Almost like my feed from the DVR to my workstation is poor, tried connecting to same hub(local!) same issue.
Abandoned the Web feed and tried using the supplied software instead which failed to load on my laptop but works fine on workstation.
Again the same issue of low quality feed and picture jumping about, my issue being if i want to actually look at it to see anything in the evening it's close to useless especially in dark areas, theres so much picture noise going you couldn't see anyone.
I called Samsung support, much as the guy was a pleasant chap he didnt really have any answers, a pointer to firmware but i am pretty sure mine is loaded with that already, will have to check tonight.
Ive setup DYNDNS etc and locked down security as much as possible for external access, I downloaded the iPolis mobile app, which works pretty good. Still a bit shaky feed but im happy to get a data feed over O2 period!
Back to my image quality and activeX issues, anyone care to share any wisdom on above?
Am i expecting too much here?
Fyi i have a monitor and VGA lead arriving tomorrow so i can test via monitor connected direct. Its not really what i want because we want to be able to monitor cams via laptops in house/external not a direct connection!
Also one other thing regards to dome.
I have one setup almost perfect but i need to pan or zoom out slighly, i noticed some colars with screws on sticking out on the lens but didn't know if they were factory adjusters to i slide up down or twist collar to zoom out, i need a wider shot, and apparently this dome is adjustable.
Thanks!!!
DVR Equipment
Thanks!!!
