Running Traps
25 Oct 2014
Essex
The waste outlet on a new sink is lower than the old one, and fitting a standard p-trap would leave it lower than the existing pipework (so no natural run-off).
A solution would be a shallow trap (eg shower trap) which would then go into a running trap in the pipework, but I gather running traps are prohibited by most authorities. Any reason why? It would save re-routing pipework through the wall etc
Roger
or use a short flexi to join trap to waste, as long as the existing waste isn't now level with the bottom of the basin otherwise water will just sit in the bottom of it.
Hi, thanks for reply.
Perhaps I misunderstand you, or maybe I didn't explain myself properly. A standard P-trap would leave me with an uphill run in the pipework. A telescopic trap would simply lower the outlet of the trap, making it worse!
Roger
Thanks for that PotatoHead - I didn't know of it. I'll look into it
However, it still doesn't answer my basic problem; a running trap would do the job just as easily (and cheaper) so why are they prohibited?
Cheers
Roger
Prohibited on a USA site that popped up on google :shock: I`ve never heard of them being prohibited over here :?
Thanks Nige F, unsurprisingly I'm no expert on the plumbing codes (though I do follow the main rules)
I wonder whether the problem with running P traps, with kitchen sinks, is that there is more risk of blockages occurring, given the stuff that goes down them. Presumably the further away from the bowl outlet, the less the pressure to carry it away around the trap, or even the more likely that fat and stuff will solidify?
Still, it provides such a tempting answer, I might try it; it will save lowering the whole pipework, knocking through walls, etc. It might come down to whether my kitchen fitters are in a hurry!
Cheers
Roger
No problem with a running trap but not sure about using the shower trap. Does your sink waste go out through the wall and into a gully? If so, might be worth just lowering the whole waste a bit.
Hi Squeaky, thanks for post.
By 'shower trap' I mean a shallow P-trap ('U' shape). This will keep the outlet above the level of the existing pipework. Soon after the outlet it will enter a running trap, providing the water seal.
Once outside, the pipes go into a soil stack. I don't really get your point about the gully; as long as the running trap provides a water seal, does it matter?
I agree, in an ideal world I would lower the pipework, no problem, but I don't have the luxury of time, as kitchen fitters will be here and will want to get the units in (I certainly want them finished and out!)
Cheers
Roger
Cheers
Roger
I couldn't say if they were prohibited or not. To be honest I'm not even sure why I don't use them- I always use a HepVo trap where a trap is required in a unusual run, and I agree they are far to expensive for what they are.
Cheers
Roger
you cant have 2 traps in series, the sink wont empty.
Interesting. I'm not sure why not, though I can see there might be a risk of an air lock?
IN any event, I've decided, it's best to do the job properly. Lower the pipework and cut a new hole in the wall. There's enough of a drop on the outside to connect to existing pipework outside without having to cut a new hole in the soil stack.
It's a pain, but I'll just have to work around the kitchen fitters, whether they like it or not!
Thanks to everyone for their help
Roger
Thanks mfarrow - I didn't know such things existed! But then I was looking at plastic fittings, and wondered why they don't make one.
It seems the running trap brings its own problems, I'll stick to the simpler, if longer way.
Incidentally, all this comes about because the plumber who fitted the new sink a couple of years ago, just made the connections at the sink. He must have known there was an uphill run on the pipework.
Cheers
Roger
