Fair enough, but I'm not sure that we know exactly how they did that 'confirming', and how convinced we are!Two electricians have confirmed that the earth bond between the pipes and the rest of the house is good (but in my case who knows, I'm losing faith that they're even testing the right things!!).
OK. The cold water supply pipe to the shower could be electrically isolated from the cold supply pipe if it originates from a plastic cold water tank, but one would normally expect the hot supply pipe to have a good path to earth, via boiler/cylinder, immersion heaters, cold supply pipes or whatever - and presumably the hot and cold feeds are electrically connected at the shower (unless its 'works' are all plastic-bodied). One would therefore expect the shower mixer/plumbing to have a reasonable path to earth.My pipework is pretty much exclusively copper, except for waste pipes of course, currently there are no plastic supply pipes anywhere I can see...
