With buffers, we'd always fit SS plate heat exchangers for hot water.
Hi, I've been looking into them, do they work well enough to match a mains pressure DHW cylinder? Any particular make 'better' than others?
I & the rest of the British tax payers paid for that, I hope you're proud of yourself!!! Lines of people outside Food Banks & you are scrounging like that?
Poetic justice when it falls to bits in a couple of years......😀😀
Have fitted loads to buffers and the out to space heating/DHW or plates.
Not yet gutted one to a thermal store.
Lee, was reading between the lines and figured that he would be getting a Buffer.... If his installer was fitting him a therml store then he would know where his DHW was coming from..
The flow and pressure of your DHW is dictated by the flow and pressure of the supply of the water entering your property.... I would prefer to use an unvented cylinder for DHW... Just for simplicity and the ability to obtain spares from your local plumbers merchants off the shelf and the back up of an electric immersion.... add to that the benefits of hot water in the event of a power cut.....Though plates can perform pretty well too....
He he he.....The Saturday night s**g not go as planned, Dickie?...
You could argue that we're just getting some of the tax back we've paid over the years.
With a 5 year warranty there's not much to worry about.
Certainly valid points fella....👍
With plate heat exchangers you'll have no backup. However, with a big FO buffer tank & plate HE you'll have at least a couple of days hot water.
Yeah, both ways have their pros and cons....But it seems that the OP already has an unvented in the box so I don't really know what the smeg he is asking or why
Well yes, a strange way to get a tax rebate???!!
It's normal for these types of appliances to be fitted in rural areas, which invariably are more difficult to access & service. In remote areas of the Highlands of Scotland, a supplementary heating system would be recommended, for when these appliances go t.ts up - which they undoubtedly will!!
Be warned!!!
The more of this interesting post I read the more amusing it becomes!
The OP has been quite rude and dismissive to many who have tried to help him.
He wants a system using perhaps the most complicated, expensive components and requiring fuel storage, deliveries, weekly user maintenance and as pointed out a warrantee delivery which will probably have significant delays in any repairs.
But he now tells us that for LESS cost he could have a mains gas supply, Vaillant or other mainstream boiler with a service engineer or agent in the town three miles away and a system which will carry on working for six months without human intervention on its automatic controls. He can use his new unvented cylinder which he already has. Total cost £1500 for gas supply and £2000 for boiler and install.
The gist of his requirement is good hot water delivery. But he does not appear to have bothered to have measured his mains water dynamic flow rate which is the first essential!
As an aside, the economics of wood pellets is interesting. With low demand they could be sourced from waste wood but that varies according to the manufacturing industries which produce waste. Having to use felled trees for the fuel supply is likely to greatly increase the cost.
Bit like using old chip shop oil for running your diesel cars. Good idea but the chip shop staff already do that and the demand for old oil exceeds supply!
Tony
