Our front door (composite or uPVC, I'm not sure which) sticks at the bottom. I could see more of a gap in the top hinge (see image 1) than the other two hinges so I tried to narrow it by turning the allen bolts you can see in images 2&3. This did seem to work - but only for a day or two.
I have a few problems/questions:
- There are allen key bolts on either side of the hinge (see images 2&3). My thinking is that I need to tighten one side and loosen the other to get the hinge to pull in (or out), i.e. to narrow or widen the gap. Is this right?
- What does the small allen key bolt in the middle do? (See image 2)
- I seem to have rounded out one of the allen key holes, probably by using the wrong size key. Is my only option to replace the hinge?
- Does anyone recognise this hinge and know where I can buy a new one?
- How do I get at the screws that are fixing the hinge to the frame?
Thanks,
Martin
Thanks,
Martin
