Do you install gas boilers?? Well you need a lesson on waste pipes & drains!!
Follow the MIs, simple enough, if you had any form of formal education you can read can't you??
Get it into your thick skull, drains & waste pipes need air, air behind water.
Over the last week or so I've been on jobs where condensate pipes are terminated with the brains of a 3 year old; double traps, pipes running uphill, pipes going nowhere......etc, etc,etc.
Air needs to be involved & traps are traps, follow the boiler manufactures installation instruction doh!! They're not all the same!! Condensate pipes need a gradiant & should be terminated where there's air.
Your ACS are just a simple course, you're not intelligent, just a wrench monkey.
