condensate into sink waste
15 Aug 2007
How do you 'tie' a combi's condensate drain into the waste. Is there a special fitting that needs to be used
condensate pipe is going to come behind the sink. Its a standard P trap.
Many thanks
Use a 1 1/2" waste T and a R17 adapter from the waste branch on the T to reduce it to overflow size.
If you use a compressuion T it will fit any size 1 1/2" waste pipe you already have.
Or even just buy a condensate tee from plumbcentre no need for reducers etc as the centre is already 21.5mm cost about £4
