Hi.
I'm in the process of a garden renovation, I've knocked down the old garage and I'm moving it approx 25m further away from the house. The old garage was fed by a 4mm 3 core SWA cable, this cable sticks out of a wall where the levels drop by about 6ft, I'm wanting to extend this connect above ground and then dig the cable in underground (finished depth will be 400 mm.)
My questions are.
1. If I just continue this old feed will I encounter a voltage drop to my new garage, that will make in unusable. The current cable is approx 15M from the main consumer unit so the overall length will be approx 40m from the main consumer unit.
2. What's the best connector to join the two SWA cables above ground? I want this to be as secure as possible.
3. I was thinking of running some 2.5mm cable back in the opposite direction while I have a trench dug to run a plug socket, does this need to be armoured? Which cable will I need? I may also put in some decking lights, what supply will I need for this
In the garage I will be running 2 or 3 sockets, a couple of fluorescent tube lights and an external PIR light.
Andy
My questions are.
Andy
