The guy who skimmed the plasterboard in our utility room last week doesn't seem to have used scrim tape on the walls or on any of the internal corners (but he did put tape on the ceiling joins). Now we have hairline cracks in the walls along many of the board joins. The corners around the ceiling haven't cracked yet but I expect them to before long. He needs to come back and finish two walls but first I need to decide whether I really want him to continue and how to fix things.
He's already skimmed the ceiling and two walls but two more walls remain. Is it worth scraping off the skim around the edges of the ceiling and in the corners so that I can tape before the final walls are skimmed?
I've come up with the options below for fixing the cracks but none of them seem ideal. Any further suggestions? Is this even worth worrying about?
Full story for what it's worth. We took a bit of a risk and had a friend do the work. We'd heard he was good at plastering and he needed the work, plus the finish of the room isn't critical. I plasterboarded the room myself but I've tried skimming before and it didn't go too well so I thought I'd get someone else in. Turns out this friend is pretty good with a trowel and to be fair he got a nice smooth finish but he doesn't know or doesn't care about "details" like tape. My wife was around while he was working and she saw him tape the ceiling before he started but I can tell that he hasn't taped any of the internal corners and I can't see any sign of tape on any of the walls that are cracking. It's possible that the boards have moved a bit but I really don't think that's the problem here. No cracks in the ceiling where I would expect the most movement.
a) Scrape off a few mm of skim each side of the cracks the width of the scrim tape, stick the tape on, PVA, multifinish. I've done this for small holes that needed filling with a small square of board. No cracks yet but the skim is hard to scrape off.
b) Use a belt sander or angle grinder or drill with a flap wheel or disc instead of scraping, then do as above. Very dusty.
c) Use some magic filler and hope that the cracks don't appear again. Is this even worth trying when I know that the joins haven't been taped?
d) PVA the whole wall and ceiling, tape, and get everything skimmed properly. Extra time and expense.
e) PVA, tape and overskim just the cracks. Sounds like there would be a visible bulge in the wall.
