My first post here, and I could do with some advice re. the central heating system in the house I bought a few months ago. Basically, what seems to be happening is that the central heating is losing pressure when turned off, but when I let a bit more water in and run it, it goes over maximum pressure.
Before I go into full details, a few bits of background info that might be useful. The house is a Victorian two-up-two-down, but with a loft conversion, so effectively three floors with radiators on all of them. The central heating is a sealed system, powered by a Sime Format C combi boiler. I had it serviced last week by a reputable local firm, who gave it a clean bill of health.
Anyway, what's happened in full is this. The system pressure should be about 1 bar when it's cold - so the engineer informed me - and so it was, but when I bled the radiators yesterday (and the one at the top of the house badly needed doing) it knocked the pressure right down to 0. So I opened the valve and let enough water in to bring it back to 1 bar.
So far so good, but when I turned the heating on again it went up over the maximum 3 bar mark, and there was a drip from what I assume to be the pressure-relief valve, on the outside wall behind the boiler. Realising that I'd over-pressurised the system I switched it off and let a little water out via a radiator bleed valve, until the pressure in the still-hot system went back below 3.
Again, so far so good, but when the system cooled right down the pressure gauge went back to 0 bar. Obviously it isn't a good idea to run the system without pressure so I let water in and bring the system back to 1 before starting it again. That seemed to be fine, and it ran comfortably at 2.5-3 bar for a few hours, but again, when I turned the system off it went back to 0. It did this again whilst switched off overnight, after running well yesterday evening.
Wondering if it might be a gauge fault of some kind I switched the boiler on experimentally this morning with the gauge showing 0, but I could hear the pump trying to work, so turned it off again and gave it a bit more water. Again, it ran absolutely fine, albeit slightly over the 3 bar mark, and again with a small drip from the relief valve. Since then I've let it cool down part way and then turned it on again with the pressure at about 1 bar, and it's currently running comfortably at 2.8ish with no drip from the relief valve.
Excuse my ignorance here, but I'm a bit stumped. The boiler's evidently working fine, the pressure gauge seems to be accurate, and there's no sign of a leak anywhere. All of the radiators are fully bled and there are no noises suggesting air in the system. Obviously the likely candidate is the relief valve, but I'm not sure it is actually that since it's not dripped except on the two occasions when the pressure's been over 3.
I've an engineer coming again this week to replace the timer clock so will mention it to him, but before that, any suggestions gratefully received.
