I have a Vokera Linea 24 boiler, BG serviced it and now the dhw flow is crap and not very hot , kicks in at 30 and off at 60 the dial (dhw) is turn right up (seems when they touch it something goes wrong) normally a bit of tinkering gets it to work but not this time.
When hot water is running the hot flow on the central heating gets hot but if I take the motorised valve off and push the pin in and run the hot tap the pipe stops cold.
The needle on the pressure gauge bounces when the hot tap is ran is this normal ?
Is this a sign its the diverter valve or the motorised valve that's at fault ?
Would a blocked domestic heat exchanger cause back pressure enough to make the diverter valve to pass ?
The central heating is working fine .
Many Thanks Darren .
