hi,
Realizing that my radiators were still very hot after 10pm when CH was off (from the Programmer), I checked the 3-port valve. The lever was floppy - easily back and forward.
I flapped the lever from the 'Auto' and 'Man' about 10 - 15 times - then heard a sound and the lever was back to the 'Auto' end. The strong resistance can be felt if I tried moving it. About 15 minutes later, the radiators became cold. Next morning, CH was on and off at 10pm. The radiators were cold as expected. Checking the lever. It was in the 'Auto' end - right position (HW only, I suppose).
Everything seems working. However, one week later, the exactly same problem occurred again. I did the same, except more times on flapping the lever to make it back (or firmly staying in) to the 'Auto' end.
Like this, it comes and goes, about once a week since last month. Can anybody give me some advices? I am afraid, sooner or later, I am not able to bring the lever to the right position anymore......In fact, the head (actuator) was just replaced in June 2014, due to similar problem, as I posted at http://www.diynot.com/forums/plumbing/radiator-is-always-hot-even-with-ch-off.402776/. It has been working perfectly until last month (Jan 2015)...
(This morning, when both CH and HW were on in the Programmer, I was feeling the lever. It has some resistance - can be moved a bit in the middle. Correct positioning? Then I 'OFF' CH through the programmer and checked the lever. It was in the 'Auto' end. Then, 'ON' the CH, checking the lever again - it has resistance, seems normal. However, a 'tick', 'tick' sound can be heard, about once per second. About 30 minutes later, the 'ticking' sound was gone. Is this abnormal?)
Thanks a lot for reading this a bit long message, and look forward to your suggestions and helps,
Cheers,
David
Cheers,
David
