Hi
I have a Worcester Greenstar 28i Junior boiler, Drayton LP111 and a Drayton RTS8 room stat.
Water is on the combo boiler and is fine. Heating is the issue.
Wiring is as follows:- from fused switch there is a live neutral and earth into their normal positions. There's also a live and return from the stat. This is wired into positions one and three on the LP111
The stat is wired into the live and position 2. Per the instructions.
There is also wiring going back to the boiler, live, neutral and earth connected to the same connections as the main switch. Plus two other wires. I know not where they go. I also doubt the connections to the stat.
Any ideas where I can start? Currently off is on and timed function are reversed and on is off.
