I'm having a confusing time with my central heating and wondered if anyone can suggest what the cause of the problem might be?
We have a Glow-worm Ultracom 30hxi boiler which provides CH and HW. Tanks in the loft and HW cylinder in landing cupboard. Boiler fitted 2009.
Here's the problem...After the central heating comes on it only runs for about 5 or 10 minutes and then goes off and stays off. However if I go to the thermostat in the hallway and turn the dial DOWN until I hear the faint click and then turn it straight back UP again to 20 degrees, the boiler restarts and then keeps running as normal.
There are no error codes showing on the boiler and no weird noises.
The same thing happens every time, not randomly.
Is it a faulty room thermostat? When I turn the dial I can hear the'click' although its very faint. If I set the thermo very low, the boiler stays off. Hot water seems ok.
Anyone had this before?
