I am looking for a solution to a problem for controlling garden lights and a pond pump with OpenRemote - a home automation controller.
I am in favour of installing two 12A 240 VAC relays, that have a built in web server that can be controlled by OpenRemote.
I plan to install two appropriately sized RCBOs into the pond and lighting circuit and connect these to the relay's load circuit. The relay's control circuit would then be connected to my Ethernet switch (PoE).
Is this type of installation covered by and allowed under Part-P, or should I look at buying a serperate DIN rail enclose such as this, leaving the RCBOs in the CU and the wiring from the CU to the enclosure?
Any advise on the subject will be gratefully received.
Many thanks
W.
Many thanks
W.
