There is none on their site.Do they not sell leaded for use on CH & HW pipes?No, the thick plumbing solder is lead-free - for potable supplies.
Do you think plumbers would bother to carry two types and (hopefully) use accordingly?
All true, but IMO all this fuss about lead in the solder used in plumbing is probably an example of an almost ludicrous degree of bureaucratic 'ultra-caution'. When one remembers that, for centuries, many people spent their whole lives drinking water that had come through pipes made entirely out of lead, the tiny tiny bit of exposure of the water to the solder joining copper pipes surely fades into total insignificance?Water hardness is an intrinsically related factor. Hard water = scale in the pipes = less lead in the water. Soft water = no scale + lower pH = more lead in the water.People other than myself will have to judge whether any of that applies to me (in my case 50-60 years later)![]()
For commercial work non leaded is OK but for DIY it's not safe and it is much healthier to use leaded solder. The problem with non leaded is the flux that must be used. It requires very good fume extraction.
Read the COSHH regulations on the flux required for non leaded and you will never use it again.
Do you mean that it has a little naturally occurring lead in it (which wouldn't surprise me)? AFAIAA, the addition of any tetra-ethyl-lead as an 'anti-knocking agent' (resulting in higher octane fuels) has been completely banned in nearly all countries, other than in aviation fuel.Just a point regarding petrol mentioned. Unleaded petrol (95 octane) does contain lead; it just does not have any more added as did four star (98.) and five (100).
Solder ring fitted are unleaded. You used to be able to get both, but then manufacturers phased the leaded versions out.I wonder what's in Yorkshire fittings?
Quite so - and, as I said, I don't know whether any 'naturally occurring lead' remained when then stopped adding it. The important point of what I said is that what they were adding (tetraethyl lead) was dramatically more hazardous to man than any lead in tap water which has flowed through lead pipes, let alone thgrough lead-soldered copper pipes.No, Don't be silly.... Seriously, I don't know the technicalities of the process. ... Merely that when unleaded petrol was introduced no lead was removed from the product, it just ceased to be added.
