I'm about to start a little project to build out our existing chimney breast - the TV is already mounted on the chimney breast itself - a stud frame will enclose the chimney breast but leave a recess for the TV mount and a flex outlet for the power connection to the TV. Cables will be hidden inside the false wall.
Here's a Sketchup model that gives you an idea of what I'm doing:
https://dl.dropboxusercontent.com/u/570528/Chimney Breast Framework - Frame.png
https://dl.dropboxusercontent.com/u/570528/Chimney Breast Framework - Fittings.png
Note: the TV itself will not be recessed into the false wall, but the recess allows the TV to be pushed back up to it with the mount inside the recess, so it doesn't stick out any more than necessary.
I've already planned the route for the power cable inside safe zones - the flex outlet will be connected to an FCU on the left side of the false chimney breast (in the alcove). The cable will run up the inside corner of the alcove, along to the top and down the front to the outlet.
I'm still trying to figure out the best approach for running the HDMI and speaker cables - I'd like to put them in conduit so I can pull new cables but I don't want to build out the wall too much. Cables will exit from brush plates on side and in recess.
I'm just about to order my timber and plasterboard (I'm using 63x38mm CLS) and I just wondered if there's any general tips you can give me for making sure I build this thing properly, square and level.
Any essential tools that will help me do a good job?
What are the best fixings for the plasterboard?
The false wall will be skimmed along with the rest of the room. Does my stud work in the above sketch look sufficient?
Any tips on notching/cutting holes for running cables?
Should I leave a small gap between the floor and plasterboard? If so how much? (I probably need to consider that our existing floorboards are probably going to be over-boarded before we have laminate put down).
Thanks!
Thanks!
