Hi Guys got a band of 2meters of engineering bricks at the base of the house and I want to clean them up and make them look great and red again.
1 Should i use brick cleaning acid first with a stiff brush or wire brush
2 should I use boiled linseed oil to then rub into the bricks and should you dilute the linseed oil or use it neat.
3 should I bag rub it instead of using the linseed oil and when bag rubbing what mix should I use to get the desired affect
Thanks for your help
Cheers Phil
Cheers Phil
