Rendering Pond walls
1 Nov 2006
Lancashire
I`m currently building a concrete block pond .
I`ll be rendering the internal walls next , prior to painting .
Just wondered if its possible to use 1 coat of render as long as the walls are flat , or does it have to be 2 coats .
Also , what is the minimum thickness required ?
Any advice would be a great help :)
Are you using a butyl rubber lining?. Is the render mean't to be the waterproofer? or if not what do the waterproofing agents instruction say?
Frank
