I have a new Vent Axia vasf100t, it needs L, N & LS (switched live?). I am replacing a 30 year old Xpelair which did not need LS. Some facts
1. I have a light switch (that obviously turns on the lights)
2. I have a second switch to control the Xpelair.
3. The Xpelair cannot operate without the lights being turned on
Obviously the fan switch is in-line with (and after) the light switch. I do not know if the fan switch is a one or two pole switch.
A friend fitted the Vent Axia by using only the L & N, this appeared not to work (he did not wait the 15 seconds for the fan to start ... this fan has a delayed start). So then added a live to LS jumper on the fan, when the mains was turned back on - the fan PCB blew up with a puff of smoke close to the terminal block.
I can replace the broken fan with the model without a timer, as this only has L&N (no LS). However, would prefer the timer model ... how should the LS be wired in to a L & N cable feed? Or does the whole switch wiring need changing to reflect the 3 pole isolator as per http://www.vent-axia.com/files/pdf-downloads/446652 B.pdf
Lesson learned ... get an electrician not a friend to do work!
Dave
Dave
