Hi all,
Before I go and start tiling, and before I call a part P certified electrician to sign off my work. I would like to get your opinion please.
I have added 3 spurs in the kitchen off existing sockets.
1. I have a 30a cooker circuit with 6mm2 flex onto a cooker switch and socket combo (this already existed when I purchased the property) - I spurred off this switch with 6mm2 flex onto a 3a FCU. From that I ran a 2.5mm2 flex in the drywall which runs behind the wall cabinet and then across behind the oven hood chimney, to which the hood will connect.
2. I also spurred off a different 2.5mm2 socket onto a 13a FCU using the same 2.5mm flex, and from that ran a 1.5mm2 cable in the drywall up under the cabinet for lighting.
3. Exactly the same as number two but opposite wall.
All spurs are located next to the socket I spurred off off and are not in any zones.
Can anyone invisage any problems with this? Anything I need to remedy before I start tiling?
If all is good, I'll finish my tiling and get a sparky in to sign it off.
Thanks for your time.
