Will New Radiator Affect Cabling ?
18 Dec 2006
Angus
I am about to install a full new central heating system in my home and am just wondering about one potential problem - I have two cables, one for phone and one coax for Virgin Media TV/Broadband running alongside a skirting board in my living room where a radiator is going to be installed under the window. I am wondering if these cables would be OK in such close proximity to the radiator ? I could alternatively move the cables to run along the underside of the window sill, but that would still be right next to the radiator. Will the level of heat from a radiator be a problem for such cabling or can they withstand such heat without trouble ? My alternative will be to re-route the cables up above the window and around it, but I will need extensions for that.
Thank you
won't be a problem,
tuck them under the carpet and never let them be seen again :D
Hi, thank you - its a bit messy though under the carpet with a lot of nails etc so do you reckon it'd be alright under the window sill just sitting above the radiator?
