New radiators not heating
1 Sep 2008
Middlesex
I have had 2 new radiators installed and niether one of them heat up as much as the others. I have noticed that one of the pipes that feed the radiator is very hot whereas the other pipe is not so hot and neither is the radiator itself. After a long time the bottom of the radiator is not as hot as the top. I have made sure there is no air in the radiator and both of the valves are fully open. I am not a plumber so don't really understand what the problem could be - they are both brand new radiators and the boiler itself was replaced a year ago.
Check out the FAQ's regarding balancing radiators....basically this involves restricting the flow through some of them so the other ones can get their share of hot water.
John :)
You say you 'had them installed' did the fitter not get it running properly in the first place or was it fitted by a non plumber friend or whatever?
