Now getting round to sorting out a faulty downlight I found when I moved in to my house.
I had disconnected at the junction box as soon as I found it! Just getting round to fixing.
The burnt out half of the connector block had a loose wire, which I assume was the cause.
I've checked the grey supply cable from the small junction box back to a larger junction box and it is all fine. Measured the voltages under operation and they seem ok too. Damage seems to be to the transformer and at the connector.
The downlight is a 50w halogen bulb and the 4 bulbs in total operate from a dimmer switch.
Each bulb has its own transformer and I tested with one of the other transformers and it works fine.
Close up of existing transformer
Was after advice for a suitable replacement and looked at screw fix to see if anything was suitable.
E.g. Get a pre-wired transformer? (as existing cables from bulb to 12v terminals are not in good shape so replace)
For a single 50w/12v bulb is a 20-60VA transformer ok, or do I need more headroom ideally? E.g. 35-105VA
