Hi
To be clear, I'm DIYing most things, but will be getting a gas engineer to do the gas pipe work and hob installation. This post is just planning Q
1930s house, rectangular chimney breast in kitchen which I plan to open up and recess an electric oven and gas hob in and make a feature of it etc.
The chimney is 45cm deep, but we'll put a false wall a the back and the hob will only be recessed around 25-30cm in, and thus the side walls will only be close to the back hob rings, the front will be "open". Extractor will be above at 76cm or whatever it needs. No high cupboards.
The problem is - the chimney isn't wide - so I am guessing I can only open it to 70-73cm, and plan a very thin plaster to smooth, and then tile.
So the back half of the hob may be 5cm from the side wall.
I've looked at some hob manuals and they say the distance from side should be 10cm+ which I can't make fit.
So is this a law/requirement/must-do - (and thus a gas fitter would refuse to fit) or just recommended?
Rough picture below - not entirely to scale as don't know how wide the chimney internal can be made till I get going.
ETA: All I can find is "For hobs, there is an exclusion zone that extends over the hob and a further 50 mm horizontally in every direction along the work surface, and upwards for 760 mm. In this zone, there may be no combustible materials" - which I can adhear to. The entire internal walls of the chimney will be tiled and the only thing in the recess will be the etractor at the correct height
