Hi all, we've been building extension on our house and I'm currently doing most of the internal stuff like insulating, drylining and plumbing. All gone pretty well so far, but as I'm a novice and trying to fit everything in around work and family (and running!), it's slow going
The problem I have at the moment is that the main water supply enters the house into what is now the kitchen, straight up through the concrete floor by a wall that is to be knocked through. This means that, once the wall is gone, it would be sticking up through the ground, in the middle of the floor. Had I been a bit more on the ball, I would have diverted it before we even put the floor slab in the new extension down, and had it enter the house a couple of feet across from where it does. Due to being a novice at this sort of stuff, I didn't do this however.
My first thought was just to create a channel in the old concrete floor and divert it at a right angle along that for aa short distance, where it can then come up again, vertically through the floor by a wall. However, this would mean having at least one joint that would need to be underground - something I'm guessing is best avoided. So, I'm a bit stumped as to the best solution. Will I just have to put a joint in and hope for the best? I'm used to using copper pipe with brass fittings, but would a proper soldered joint be best to use if I was forced to bury the joint? Anyone got any better ideas how I should do this? I'd be really grateful for any helpful tips from anybody more in the know than me. Thanks.
