Hi. I`ve just joined DIYnot.com and have read a few (very old) posts about extending loft lighting. Sorry if this post is a repeat of previous ones but I`m hesitant about going ahead until I`m clear about my own situation as I`m not an electrics expert.
In my loft, there are lighting and socket cables, which converge in a grey plastic box, which I assume is a junction box (20cm x 20cm). From this box, there is a single cable to a switch and, from this switch, the cable continues to a single bulb in the middle of the narrow loft, where the circuit ends, so I assume this is a `spur`.
I simply want to add 3 bulbs to the left and 2 to the right of the existing bulb, all controlled from the existing switch.
Should I simply put in a new 1.5mm twin and earth supply cable from either side of the existing light? Or should I run 2 separate cables from the switch to serve both sides of the loft? Do I need an FCU for so many bulbs on a spur? Would I need to do anything different if I chose to go for 3 fluorescent tubes instead of 6 bulbs?
Thanks. Moyzzie.
Thanks. Moyzzie.
