Hi All,
hope you can offer some advice!
My fiance and I are decorating our first house and as part of that I'm replacing the somewhat dated white light switches with something more stylish.
The only place in the house that I need a two way switch is the stairs/landing. This is how it looked -
Although it may not be clear, the left hand switch is purely for the hallway light. This is one way and works fine, although there's a loop from the bottom to the bottom of the other switch. The right hand switch for the stairs/landing has a red in 1, black in 2 then another red in the bottom.
They are intermediate switches but aren't making use of all the connections.
So - I've replaced this double gang switch with a 2 way arrangement, and replaced the single gang switch at the top of the stairs (also 2 way) but can't seem to get it to work.
The left switch for the hall works fine. I wired it as closely to the old arrangement as I could - so red into com, black into L1 and red into L2, mirrored at the other switch. I also put the loop from the hall switch into L2 with the other red.
How the wiring looks, for reference -
I can turn the stairs/landing lights on from my hallway, but only if the switch at the top of the stairs is 'on' - that switch itself does nothing. If the switch is off then I can't turn the lights on - so I'm obviously not completing a circuit.
I've tried a few different ways of wiring it but no joy.
I have a feeling I must be missing something obvious!
