My cooker circuit occasionally trips - usually once every few months, but occasionally more often. I have a standard 45A cooker switch with a combined 13A socket in the kitchen, where the microwave is plugged into. I have a range cooker with an electric grill and two electric ovens (and a clock and a sparker for the gas hobs). Sometimes it trips when using only the microwave, sometimes with only the grill, or with only the oven. Normally you can have all three on with no problems. We don't use the second oven except Xmas etc, but it didn't trip then either (ie when we were probably using all four). It has never tripped with nothing being used, although the clock is always on.
It has a Crabtree B32 MCB on the RCD side of the consumer unit. The RCD is 80a 30mA, and the other MCB's are shower, downstairs sockets and upstairs sockets.
I've taken the faceplate off the cooker switch and all is good there, and I have done the same with the connection plate on the back of the cooker. Is there anything I can check relating to the MCB, or any other pointers?
TIA
TIA
