Try Gigz idea Slinky, if it's still the same then you need to get someone in to check the heat exchanger in the boiler, the bit that heats the hot water. If that's scaled up or filled with cr@p from the CH system then that may be causing your issue.
No, you shouldn't have to top it up every 2 months, you have a pressure loss somewhere. Is there water dripping out of a small pipe that will be situated on the outside wall in the general vicinity of the boiler?
Having to top up won't help with corrosion in your system and can speed up the blocking up of your heat exchanger.
