If it were feeding a single socket or FCU, the cable would be protected by the downstream fuse (13A max) in the plug or FCU, no matter what the OPD at the origin of the circuit.
Ok just checking done this right I've taken the wires from fusebox to cooker switch then cooker switch to cooker connection plate also fitted hob into connection plate then will take feed from connection plate to single socket for oven so three sets of wires in connection plate is that right
I should have took puctures i just done mine lasy night to fit new oven and hob..... Anyway now you have this connected (i would have taken the connection from the back of the outlet) but yeh you can just put a 3 core 1.5mm t&e/flex into your new socket outlet and plug in the oven
Get a electrician round to sort it mate. Don't play around with it . It's not worth it . Only take a sparky hour to sort that out . Job done safe and no electric shock for u
