putting a window in
25 Aug 2004
Cornwall
we are buying a bungalow soon. the living room has walls 3 sides with a conservatory at the long end of the room via sliding doors
its pretty dark because of that and we thought we may be able to put two clerestory windows in the west wall which has a road on that side and bungalows across the road facing south
the construction is block with render outside and i believe the property is around 25 years old
what i need to know is where to start...ie is planning necessary.
Probably not but you may want to check with the local authority that your property retains all of its permitted development rights. Often new-builds have certain restrictions placed upon them but it wasn't such a common practice 25 years ago as it is nowadays. That said, as you are in the process of buying then this information should be made available to your solicitor during the LA searches.
ok i will
should i get quotes or just frame out the intentions on the questions form
i have building connections and can get a quote with specifications reasonably easily
i will contact CCC planning and building control to get some idea of the proceedure as well
the upper edge of the proposed window opening will be at least 6 courses down from the roof plate so i guess there will be a necessity for a lintel or reinforced frame for the proposed window frame with a post half way along
my estimate now is around 1200x400 and using 2 windows one on either side of the fireplace
