My hallway ceiling was washed, filled, sanded and sealed with a mist coat and in places of high repair a 50/50 pva to seal it, prior to 3 coats of Wickes white matt - I'm not sure if it was standard matt or vinyl matt?
Despite all this solid white paint put on with a short hair roller for minimum 'stippled' effect and a hoped for smooth and matt finish, I have just that problem. Close up the surface is very uneven, quite 'grainy'. The light also catches a few patches that do not fully cover, no matter how many coats are put on.
I am thinking of sanding it back with fine paper (by hand) and building up the body of paint layers again.
> But how do I proceed?
> After sanding, do I seal it so that the new coats build up a blocking coat and what roller?
> Do I use a short haired roller for a smooth finish? I would assume so.
Any help much appreciated
