The shut off valve is above a wide diameter pipe which comes up through the ground into the meter cupboard and then runs into the left side of the meter. I'm assuming that's the supply pipe. The one on the right side of the meter also runs into the ground so I can't be sure but it is a normal sized pipe.
Neither are in places where I could get to the consumer unit without taking the floor up. I notice the copper water pipes around the boiler are earthed to a nearby electric point. Can you do that or does it have to go to the CU? Thanks
