It sounds as if you might have some interconnections between circuits, so you would have to pull out more than one fuse to remove power from a circuit. If that is the case, then it is dangerous and should be properly investigated straight away.
The chap who owned our house before us clearly believed he had more electrical knowledge than he did...
He decided to fit a second, smaller, consumer unit next to the original wylex board. He fed this using 4mm2 singles
