Central Heating Is This Consumption Ok ?
30 Sep 2015
I moved into this property at the beginning of the summer, it has a five year old Baxi Due-tec 28 combi boiler, with which I hope to stay warm and pay as little as possible, I have not as yet been operating the CH system.
I am still spending my evenings in my south facing conservatory in which I have one central heating radiator which is a double panel type and measures 700mm x 695mm.
After dark one evening I turned off all the other radiators in the system read the gas meter and then turned the room stat in the main building up to max, closed the door from the house into the conservatory and operated the CH continuously for 3.5 hrs.
At the beginning of this test the air temp. in the conservatory was 62f and at the end 75f and I had used 0.88 cubic meter of gas which I believe works out at 9.73 kwh.
Do you think the boiler is performing as well as it could.
A conservatory is an uninsulated shed. It should not have radiators in it unless you want to warm the sky.
Have you considered burning a pile of £5 notes?
you dont mention the outside temperature and any possible solar gain during the experiment
Oh seems like I am being a little misguided, how do you check that the boiler is running at its most efficient, does it require instruments,and what does one check and adjust, or do you have to call in a engineer.
You get it serviced, and during the service it will be adjusted to perform at its most efficient
You can also increase efficiency by turning the boiler thermostat down, and by running more than one radiator. Oh, and by turning off your conservatory radiator altogether so you're not warming up the world
