Boiler only ignites when front cover is removed
Status
Not open for further replies.
16 Oct 2015
Hi, I have a Halstead Ace High, it will only start up when the front cover is removed or partially off.
A typical symptom of the air pressure switch at fault I am informed which is logical, this has been replaced as has the pcb for a different fault,
Anyone experienced this problem before
<Moderator's note:>
This site does not support DIY gas and posts giving advice on gas work, or encouraging or suggesting it, may be deleted.
Turn it off. Do not use until checked and given the all clear by a gas safe registered engineer. The symptoms you describe suggest insufficient oxygen for complete combustion (hence no flame and boiler doesn't start). Insufficient oxygen = incomplete combustion = too much Carbon Monoxide = death.
Status
